Phil_Dunphy
Jun 23, 2024 5:39 PM UTC
Syncing Two Widgets
I am developing two different widgets in two separate folders and I am trying to sync the data in both widgets together. From Widget A, I can press a “Send” button and it will send the data from Widget A to Widget B and navigate directly to wherever Widget B is at. But I want Widget B to automatically fetch and display the data from Widget A as soon as I navigate to Widget B using
Figma.currentPage.selection = [WidgetB]
Figma.viewport.scrollAndZoomIntoView([WidgetB]);
Right now after I have navigated to Widget B, I have to create and click on a “Fetch” button in Widget B in order to fetch and display the updated data. I have tried setting up event listener to trigger the fetch function, but I assume the Widget B is not in an “active state” when I navigate from Widget A to Widget B that why the event listener isn’t triggered. Is there any solution to solve this issue, this is my first Figma widget project and I have been trying to solve this for days, any help would be really appreciated.
GlebSolution
Power Member
Jun 23, 2024 9:33 PM UTC
Unfortunately a widget can’t trigger another widget. User action is required.
Phil_Dunphy
Jun 23, 2024 7:22 PM UTC
Any better alternative or workaround suggestions are welcomed as well. Thank you.
GlebSolution
Power Member
Phil_Dunphy
Jun 23, 2024 11:17 PM UTC
Alright, thanks for clarifying. Just for future reference,
A) Is there any way I can open the Widget B directly from within Widget A, for example through clicking a button.
B) Is there any way to create a brand new widget with completely different component design, functions and property menu from within another widget. Or is it better to create two different widgets instead.
Power Member
Jun 24, 2024 4:48 AM UTC
No
No, widgets can’t create other widgets
Phil_Dunphy
Jun 24, 2024 5:56 PM UTC
Okay that’s helpful, thank you once again.
