Alessandro_Viatore
February 12, 2024
Shadows not shown with transparent fill
I have ghost buttons (i.e. with a transparent surface), I would like to apply a box-shadow to simulate focus-tab but nothing is shown, the only way is to assign a coloured fill.
I understand that I’m basically removing opacity from the fill so applying a shadow to it is almost not logical, but this is feasible in css.
I wonder is there some trick or other to way to solve this?
dennsi
February 12, 2024
A trick would be apply a fill with 0.01% transparency.
Drop shadows need either a fill or stroke that is opaque to get shown.
For some unknown reason, the trick does not work for strokes.
Alessandro_Viatore
February 12, 2024
Thank you!
yes so this will works, but I have to detach the variable and then the developers will ask me about this change
dennsi
February 12, 2024
You could create and use a different variable and inform your dev to ignore it because you needed to use it for a workaround.
Alessandro_Viatore
February 12, 2024
yes I wouldn’t want to create a variable just for this issue, but thank you I appreciate your suggestions 🙏, I hope they can fix it, I have few more components that do not need a fill but need a box-shadows
dennsi
February 12, 2024
No problem you’re welcome.
I’m wondering, if the components do not need a fill, why is a fill variable or style necessary in the first place though?
Alessandro_Viatore
February 12, 2024
To simply tackle future changes, IMO is always better have it something set at components level
July 16, 2024
I ran into this problem myself. This is just a bug and it ought to get fixed.
