davor.radisic
Aug 21, 2024 12:09 AM UTC
Selection issue
I have 360 variants (120 x 3 Sizes S, M, L) in my button component. There is an instance of the badge component in each of them. Now, I want to select only the badge instances in the size M.
I managed to select all M size variants. But how to select the instances “badge” within?
Aug 23, 2024 2:28 AM UTC
Hi there,
Thanks for reaching out. I wasn’t able to select instances in size M. I could use “Select all with the same instance” via quick actions but couldn’t specify just one property of the instance.
You might want to explore the Community to see if there’s a good plugin for your use case.
I hope this helps!
Toku
