Select frame plugin
  • August 31, 2023
  • 1415 views
Hi everyone,
I’m working on a plugin, and when I select an art board, I want to make its image, display it in my plugin UI, and send that image data to the API.
I have data in the form of a Uint8Array. It needs to be converted to an image, which I found is possible if it’s in base64.
I have installed multiple libraries through npm e.g npm install uint8-to-base64 but it fails to load when I do import { base64_arraybuffer } from 'uint8-to-base64' it always says Cannot find module 'base64-arraybuffer-converter' or its corresponding type declarations.ts(2307)
import { base64_arraybuffer } from 'uint8-to-base64';
figma.showUI(__html__);
figma.ui.onmessage = async (msg) => {
    const selectedArtboard = figma.currentPage.selection[0];
    // Export the artboard as an image buffer.
    const imageBuffer = await selectedArtboard.exportAsync({ format: 'PNG' });
    // Store the image buffer in a variable.
    const image = imageBuffer;
    console.log(image)
    const ReimageBuffer = new Uint8Array(image)
    var dataURL = base64_arraybuffer.ab_2_base64(ReimageBuffer)
    console.log(dataURL)
While the library is installed and it’s there already, I tried looking up on internet as well
some suggested I should ammed tsconfig.json and add "paths": {."uint8-to-base64":["./node_modules/uint8-base64"] } should solve it but doesn’t help.
Any help in the direction, it feels like i’m close to get this done if I have the image converted into base64 I can display that in the image tag.
Thanks, please do let me know If I have missed anything to mention or If you need any further information.
Thanks again.
Best answer by tank666
figma.com
tank666
tank666Answer
September 1, 2023
September 1, 2023
Thanks for the reply, I’m unable to get Uint8Array to even be base64, once I get to the base64 string, I can manipulate it but main challenge is the conversion to base64
tank666
September 1, 2023
Did you use the method I linked above?
