Jimmy_Morris
Jul 24, 2024 9:05 PM UTC
Question around `documentUrlSubstitutions` for Code Connect config
I’m trying to setup my code-connect project very similar to @figma/sds where in the figma.config.json file they’re in a rather clever method of leveraging documentUrlSubstitutions to do value replacement for the Figma document URL.
Config
  "codeConnect": {
    "include": ["./src/components/**/*.{tsx,jsx}"],
    "exclude": ["**/utils/*"],
    "parser": "react",
  "documentUrlSubstitutions": {
    "<FIGMA_INPUT>": "https://www.figma.com/design/:file_id_here?node-id=:node_id_here",
Component:
figma.connect(Input, '<FIGMA_INPUT>', {
    // code is here
Error:
Validating Code Connect files...
Failed to parse <FIGMA_INPUT>
Any insights or is there a custom implementation I am missing? [details left out for privacy]
    Akbar_Mirza
    Akbar_MirzaSolution
    Sep 7, 2024 5:20 PM UTC
    You’ve probably figured this out by now - but answering so others don’t run into the same issue.
    The error here appears to be because documentUrlSubstitutions is not nested under codeConnect.
    The config should look like this instead:
      "codeConnect": {
        "parser": "react",
    Hopefully, that helps.
    Akbar_Mirza
    Akbar_MirzaSolution
      "codeConnect": {
        "parser": "react",
