Josh_Cusick1
Sep 27, 2024 9:12 PM UTC
Pick what overrides I want to reset with Plugin API
Is there a way to reset all overrides except ones that I select? For example, let’s say I want to swap in a new Button but I don’t want to reset the character property, I want to preserve what the user has typed in the label text layer.
The only method I found in the Plugin API docs is the resetOverrides() does not take any argument.
It would be super cool if I could pass in what I don’t want to change e.g. resetOverrides(!node.overrides.character)
Here is my WIP code to swap out old components with new ones:
// main.ts
import { getSelectedInstances } from "../app/utils/getSelectedInstances"; // Adjust the path as necessary
// Clear console on reload
console.clear();
// Default plugin size
const pluginFrameSize = {
  width: 320,
  height: 380,
// Show plugin UI
figma.showUI(__html__, pluginFrameSize);
// Import the component map
import { componentMap } from "../app/data"; // Adjust the path as necessary
let componentCount = 0;
// Function to swap button components
async function swapButtons(state) {
  console.log("Swap state received:", state); // Debugging log
  // Iterate over each component in the map
  for (const component of componentMap) {
    const { oldParentKey, variants } = component;
    // Get nodes based on the state
    const nodes =
      state === "bySelection"
        ? getSelectedInstances(figma.currentPage.selection) // Use the current selection
        : figma.currentPage.findAll(
            (n) =>
              n.type === "INSTANCE" &&
              (n.mainComponent?.parent as any)?.key === oldParentKey
          ); // Use findAll for "byPage"
    // Log the nodes found
    console.log("Nodes to swap:", nodes);
    // If no nodes are found in selection, notify the user
    if (state === "bySelection" && nodes.length === 0) {
      figma.notify("No instances selected for swapping.");
      return; // Exit the function early
    // Iterate through each variant
    for (const variant of variants) {
      const { newComponentKey, keywords } = variant;
      // Import the new component once
      const newComponent = await figma.importComponentByKeyAsync(
        newComponentKey
      // Ensure the new component is imported before proceeding
      if (newComponent) {
        // Iterate through all nodes and check their names
        for (const node of nodes) {
          if (node.type === "INSTANCE" && node.mainComponent) {
            const name = node.mainComponent.name;
            // Check if all keywords are present in the name
            const allKeywordsPresent = keywords.every((keyword) =>
              name.includes(keyword)
            if (allKeywordsPresent) {
              node.resetOverrides();
              node.swapComponent(newComponent);
              componentCount++;
  // Notify the user about the swap results
  if (componentCount > 0) {
    figma.notify(
      `✨ ${componentCount} ${
        componentCount === 1 ? "component" : "components"
      } swapped`
  } else {
    figma.notify(`No components swapped`);
  componentCount = 0;
// Listen for messages from the UI
figma.ui.onmessage = async (msg) => {
  if (msg.type === "SWAP_BUTTONS") {
    const state = msg.state; // Assuming the state is sent in the message
    console.log("Message received from UI:", msg); // Debugging log
    await swapButtons(state);
console.log(componentCount);
