DNLBTLR
Apr 25, 2023 1:30 PM UTC
Offset path to create "radiating" outlined shapes?
In illustrator, I believe there’s an effect called “offset path” that will give this result.
Is there anyway to do this in Figma?
Ian_Sampaio
Ian_SampaioSolution
Apr 26, 2023 3:28 PM UTC
And another method using Difference and Luminance mask. This is by far the simplest but your object will carry a masked fill (you can lock your layers to avoid messing with it)
Ian_Sampaio
Apr 26, 2023 2:44 PM UTC
To my knowledge Figma doesn’t offer layered paths and I’m afraid it will never do since it usually follows what is possible to through CSS. But here is a workaround: create a symbol with the desired path and a stroke (I added both black and white to easily alternate between the two). The effect is achieved by each instance below the main symbol getting a thicker stroke and alternate between black and white:
Figma
Ian_Sampaio
Apr 26, 2023 2:54 PM UTC
I’ve added a second approach which uses Merge. It’s a lot simpler and allows transparency but also buggier (you can try and get rid of the bugs messing with the outer stroke’s Miter angle)
Ian_Sampaio
Ian_SampaioSolution
