Awais_Iqbal
Jan 25, 2023 10:29 AM UTC
Not getting frame images separately
Hi
I’ve written Rest API for images using
https://api.figma.com/v1/images/myfilekey
https://api.figma.com/v1/images/myfilekey?ids=123456
it has multiple frames but it is returning all frames in one image in response
“err”: null,
“images”: {
“node-id”: “image-path”
The image path that is returning , it is correct path but I can’t get all frames separately
But when I change the https://api.figma.com/v1/images/myfilekey to https://api.figma.com/v1/files/myfilekey then I get all frames separately.
How to resolve this issue?
Awais_Iqbal
Jan 26, 2023 6:09 PM UTC
@Gleb do you have any idea how to get all the images separately but not in one url.
tank666
Jan 26, 2023 6:36 PM UTC
Add any desired IDs in the URL.
https://api.figma.com/v1/images/:file_key?ids=node_id,node_id,node_id
Awais_Iqbal
Jan 26, 2023 6:43 PM UTC
Yes, I’m already using this method but it is returning all images into one as a one URL.
In one node, I’ve multiple frames. And API is merging all images into and returning as a one path
tank666
Jan 26, 2023 7:10 PM UTC
That is, you want to get the image of the parent node without nested nodes (children)? I don’t think it’s possible without editing the file.
Power Member
Jan 27, 2023 4:12 AM UTC
I think you are having the exact same issue/misunderstanding as discussed in this thread: Exporting a particular image
Awais_Iqbal
Jan 30, 2023 5:49 PM UTC
@Gleb I don’t want to get multiple images from the one artboard/frame.
But I have multiple artboards/frames and I want each artboard/frame as a separate image.
Thank you for your response
Power Member
Jan 31, 2023 2:23 AM UTC
Can you show the exact URL (only replace the file key) you are using to get the images? The URLs you shared in the original post don’t make much sense.
Jan 23, 2024 12:34 AM UTC
Hey @Gleb I am having the same issue. This is an example URL: ‘https://api.figma.com/v1/images/XCBeyksAtZVzrAD6aEyjZ4?ids=2:18,296:3609’
Power Member
Jan 23, 2024 4:57 AM UTC
What’s the response you are getting?
Jan 24, 2024 1:58 AM UTC
Hey @Gleb, sorry I think I was just parsing it wrong! I get them all back 🙂
