Alaa_Monir
July 10, 2024
Mouse enter & Mouse leave problem
  • July 10, 2024
  • 11 replies
  • 953 views
I have a question about mouse enter mouse leave interaction:
In a mega menu with an overlay like this:
when the mouse leaves “Shop by” for example, the overlay doesn’t disappear UNLESS i leave the menu and hover elsewhere on the page, but for example if i hovered around “SHOP BY” and then went to “NEW” the overlay doesn’t change
HERE the figma file
I don’t know what i did wrong so if you could check the file and leave me a note I’ll be
thankful
KennLucas
July 10, 2024
Seems you posted a link to the file, which requires access. If you can upload the .fig file, we can grab it. 👍
It “sounds” a little like you just might have the interaction on the wrong place. But having the file will help figure that out.
Alaa_Monir
July 10, 2024
I approved
Alaa_Monir
July 10, 2024
Yes this is the issue
KennLucas
July 10, 2024
Sorry I deleted my post.
OK I can look closer in about an hour after work!
Alaa_Monir
July 10, 2024
Ok, thanks!
KennLucas
July 10, 2024
I am thinking that since the mouse leave is on the nav button, that telling it to close overlay…it doesn’t know what to do. When yuo mouse leave the overlay…it closes. So you know that works. But the button, is not an overlay. So telling it to close itself is not gonna work.
I think I can do this. Just need a few. Working on it…
Alaa_Monir
July 10, 2024
yeah that’s what i thought too, but I was trying everything.
anyways feel free to edit on the Figma file, and if you found a solution please let me know
KennLucas
July 10, 2024
Looking like most examples online use a variant approach rather than the overlay.
Even the Figma help site uses a variant approach, but they don’t change the whole menu. They do a weirdo thing of each item is a variant set. With button closed and button open. Then when you mouse in/out, you are just swapping variables of the single item.
Definitely the overlay thing is failing because there is no easy way to tell the menu to close. And the buttons are not resetting state to allow the other link to work.
This one is hard. I think you might be better served with a different method.
I will let you know if I can pull it off though.
KennLucas
July 10, 2024
Gotta wrap for the night.
I’ll try to do some more tests this weekend. My gut is telling me the variants approach is the way to go. It really is about all I can find onliine for examples.
Alaa_Monir
July 12, 2024
Yes, I tried it with Variants and it worked!
and it was much easier this way, thanks for help
