Dad_Zurigo
Nov 29, 2024 5:00 PM UTC
Material's "background" layer
Is there any advantage to having a separate layer for the background inside a component as done in Google Material Design, whereas Figma offers solutions to fill a container with a background color without using an additional layer? Is the approach by Material Design considered a legacy method, or is there a specific rationale behind this concept?
Pavel_Kiselev
Power Member
Nov 29, 2024 8:01 PM UTC
There are quite a few advantages to this. It can be a component you can reuse over and over again in other components of the same kind. Being a component instance makes it supers easy to enable multiple style options. When you have a large system it makes it much easier to maintain that system.
In a way, it’s like a complete style definition for an element. My favourite is the common UI element surface/chrome. It implements very basic visual states which I can reuse however I like
Have a read if you like, I put some thought around it here → Making of true multi-brand design system | by Pavel Kiselev | UX Collective
Dad_Zurigo
Nov 30, 2024 6:12 AM UTC
Thanks for sharing, Pavel!
In the design system I’m working on, we don’t handle multiple brands. I apply the background fill on the parent layer of the component. This method reduces the number of layers. The background fill color value is set through a variable, which makes it easy to manage. This setup also allows adding a theme.
I understand that the method you and Material Design use might have benefits for systems that need to support multiple brands, but my design system doesn’t require this. So, I guess I just haven’t had the challenges and complexities that might need an extra background layer as a solution.
Pavel_Kiselev
Power Member
Nov 30, 2024 9:06 AM UTC
Frankly it’s not only because of the need to support multiple brands. It’s just makes life easier.
Here is a real-life example. I have multiple flavours of a form element. And they share the same style
Basic input
Inset labels
Input group
And they all use the same component for visuals. It’s super consistent.
Plus I made a few extra styles, so I don’t need to make extra variants to support alternative visuals. Clear to see it’s way more effective when it comes to memory use.
I like that next time I decide to change something in design for my default form element it would not take lots of effort as I only change a single style component.
And some guys found it to be useful
Figma – 18 Oct 23
