Issue with moved library
  • April 15, 2024
  • 167 views
Campana_Veronica
Similar issue: I moved a library to another team under the same workspace. After doing it, the library is not enabled anymore in the files where it used to be.
The instances are still in the files, but the library is now showing up so I have to re-enable it in EVERY SINGLE file… does this have something to do with permissions in one or the other team? Any solution to avoid this?
Thanks
ksn
  • April 16, 2024
Hi @Campana_Veronica – sorry for the trouble. First, I moved your response from the old topic you originally posted on into it’s own thread (since the other one was a separate issue and outdated).
Regarding the library issue – it looks like a member of our support team (Sharon) has been in contact with you via email, and that this is currently being looked at by someone on the engineering team. If you haven’t received any reply, please check your spam folder. For reference, your case number is #974900.
If you have any additional questions, or did not receive an email, let me know.
