Neel_Sara
Dec 29, 2023 3:54 PM UTC
Is there a way to identify if a node is truly visible?
I know there’s a visible property that tells you if the node itself is visible or hidden, but one or more parents could be hidden while the actual node is visible, so visible would be true on the actual node. Is there an easy way to see if a node is truly visible, because all of its parents are visible? Would prefer not to traverse the node tree, as this seems inefficient.
Visible property: visible | Plugin API
tank666
Dec 29, 2023 4:00 PM UTC
You can check the absoluteRenderBounds property.
Power Member
Sep 24, 2024 3:25 PM UTC
Just discovered this trick, just wanna share a simple example in case anyone else stumbles upon this:
absoluteRenderBounds can be used to check if node is actually visible on canvas, in case it’s not visible because one of its parents is invisible:
myNode.parent.visible // outputs false
myNode.visible // outputs true
myNode.absoluteRenderBounds // outputs null
