Ios 13 to ios 15 or 17?
  • December 13, 2023
  • 184 views
I have a wireframe for ios 13 but I need to adjust it for the ios15 version. Is there any way to do it without having to adjust constraints to each element separately ?
ksn
@Gliese436b If you select the frame that you want to adjust, you can select “frame” on the right-hand panel and select the device parameters you want to adjust. That should adjust things quickly. Let me know if I misunderstood.
December 20, 2023
Unfortunately, not so with the components or variants inside the frame.
