step34
April 20, 2023
How to remove an imported component?
Hi,
When using " importComponentSetByKeyAsync" it imports the ComponentSetNode into memory and I can use it to create instances via my plugin.
The issue I have is that the Node is first added to the memory, but there doesn’t seem to be a way to remove it from memory if I want to. The .remove() method only works on nodes that reside in the document.
Does anyone know if there is a way to clear the remote Nodes from memory?
tank666
tank666Solution
April 20, 2023
The only way to clear the memory is to reload the file tab.
tank666
tank666Solution
April 20, 2023
