Onkel_Tem
Nov 11, 2024 8:04 PM UTC
How to cancel "WhilePressing" effect?
Hi folks.
I stumbled upon a simple Dialog open behavior. If I use a component with “WhilePressing” visual effect (like e.g. background dimming), then both onTap and onTouchUp actions won’t cancel the effect.
Here is a sample design file: https://www.figma.com/design/rC5hQVyjoS3ubnRHTmnW8D/Tap-animation?node-id=0-1&t=eLdLBq0A6LpgurTr-1
There are two pages:
  1. Page1: onTap
  2. Page2: onTouchUp
that only differ in their trigger action type.
What it looks like currently
Here is a short recording in GIF:
4
As you see, the list item remains in its pressed state. How to fix this?
Nellya
NellyaSolution
Power Member
Nov 13, 2024 10:55 AM UTC
Like this
Pavel_Kiselev
Power Member
Nov 11, 2024 10:29 PM UTC
The overlay blocks all interactions beneath, I guess the list item springs back to normal after you close it. Not ideal, nor the big deal either
Onkel_Tem
Onkel_TemAuthor
Nov 12, 2024 12:27 AM UTC
But it doesn’t, that’s the problem. Look, I’m showing this on the animation.
Nellya
Power Member
Nov 12, 2024 5:14 AM UTC
I had this problem many times. The only fix i found is to add after delay from while pressing to default state for a force returning.
Onkel_Tem
Onkel_TemAuthor
Nov 13, 2024 10:09 AM UTC
Hey Nellya!
I got the idea, however I’m not finding a way to add that after delay.
Would you please elaborate?
Nellya
NellyaSolution
Power Member
Onkel_Tem
Onkel_TemAuthor
Nov 13, 2024 11:06 AM UTC
I see now why it didn’t work out for me.
You see, I use Material Design 3 Kit components (e.g. “Card”). And they have the “while pressing” effect already built-in, so I can’t really interfere and do that.
Instead, I’d need to create the card from scratch to include the initial state restoration.
Thank you!
P.S. Interestingly, since I’ve started using Material Design 3 Kit, I only reduce the number of components I include in my designs as I have to replace them with custom components that work more correctly. So this one is just one more reason why MD3K is more a toy, and not something ready for real applications.
Onkel_Tem
Onkel_TemAuthor
Nov 13, 2024 11:13 AM UTC
Folks!
I’m picking one of Nellya’s answers as a solution. It involves manual state restoration with “after delay”. Yet, the question on how to achieve that more easily - is still open.
I would have added this text to where it should be - in the first posting, but forum rules don’t allow editing.
