Nov 26, 2023 8:35 PM UTC
How do I correctly display the outside stroke of a frame in PDF export?
Hi, I take example with this frame with blue fill.
Both horizontal and vertical resizing are set to “hug”, and it has a 4px yellow stroke.
After exporting to PDF, the outside stroke is displayed as an inside stroke, while PNG export displays correctly.
Cenk
Nov 26, 2023 11:36 PM UTC
Have you tried to outline the stroke? Afaik pdf files do not support autolayout. So it makes more sense to keep your vectors as vectors. I would be happy to help if you could specify your goal more clearly.
yc12Author
Nov 27, 2023 12:46 AM UTC
I used frames+autolayout+hug to add some underlines and borders. But unexpectedly the outside strokes were obscured by the inner elements (in pdf files).
I can convert png to pdf or use other alternatives methods. But it’s just a little frustrating because I didn’t get what I saw in the preview.
Thank you for the information.
