Gavin_Atkinson
December 8, 2023
Heavy input lag
I am making patterns with a fairly high, but not extreme number of elements, around 1000 squares. Changing the fills on these all at once causes multi-second input lag which is especially noticeable in the colorpicker. For instance, I will open the colorpicker, click (not drag) to select a new color, then click outside of the panel to close. Figma does not seem to pick up on the mouseUp event or something, thinks my cursor is still in the colorpicker and drags the color around to a value I didn’t select.
Other instances of this:
  • Sometimes happens in cases that do not involve 1000 elements, even a small component still causes this to happen.
  • Also occurs on numeric inputs, for instance layer opacity
Meta topic - this is more of a bug report. Is there a better place to post bug reports?
    Hi there,
    Thanks for flagging. You can file a bug repeport by following the steps shown in the article here: https://help.figma.com/hc/en-us/articles/360041468234-Submit-a-bug-report.
    Could you please file a bug report about this issue?
    Thanks again,
    Toku
