pov_pie
May 6, 2023
Given two rectangles side by side, how do I adjust the "middle column" of both at the same time?
  • May 6, 2023
  • 4 replies
  • 1437 views
I want to adjust the middle. So if I push the middle to the right, the red square get larger horizontally and red smaller and vice versa.
I tried selecting both and moving the middle but it doesn’t work.
Thanks.
Best answer by Stephane_Popout
I tried to make a working example here https://www.figma.com/file/RzGFzfYHTxkWai1MvQykOO/Untitled-(Copy)?type=design&node-id=1%3A2&t=QPl6kkm28CKhqr2o-1
  • I added a frame with autolayout around both rectangle and set its width to Fixed.
  • I set the green one width to Fill
  • Result: When I select the red rectangle & I can move its right border, then the green resize accordingly
Stephane_Popout
May 6, 2023
You can put them in an autolayout
And set one of the green rectangle width to “Fill”
When you will resize the red rectangle, the green will take the remaining space
pov_pie
pov_pieAuthor
May 6, 2023
Hi Stephane, thanks. I tried it but I would like both extremes of both rectangles to keep in place and move just the middle between them. Would you mind taking a look here? Feel free to make any change. https://www.figma.com/file/HEPqxBBsvO0YJrVQSrxN2t/Untitled?type=design&node-id=0%3A1&t=RgGdIXIDcKXU8XJq-1
pov_pie
pov_pieAuthor
May 6, 2023
Hi Stephane, thanks for the response. I tried it but it’s not the result I’m looking for. I would like both extremes of both rectangles to keep in place and move just the middle between them.
Would you mind taking a look here? Feel free to make any changes. 🙂
Figma – 6 May 23
Stephane_Popout
May 6, 2023
