Jan 11, 2024 2:34 PM UTC
Getting updates from the library inside the library
Do you receive the notification that components were updated in a library, after publishing the library?
Example: I publish library A. After a few minutes, I receive a notification inside library A saying some components were updated. It seems a case of inception but we get super confused with this.
Jan 12, 2024 5:45 AM UTC
Hi there,
Thank you for getting in touch. Sorry for the confusion. It seems you’re seeing a notification issue related to library assets in your files. For instance, if you have a component (let’s call it component A) from File 1 that’s used in another component (component B) in File 2, and File 1 also includes an instance of component B, any modifications to component A might prompt update notifications.
Could you provide more specific details about your situation? If you could share additional information, I’d like to replicate this on my end to determine whether it’s a bug or a standard behavior.
Thank you.
Toku
Neto_AnaAuthor
Jan 12, 2024 7:56 AM UTC
Hey @y_toku
If we think about your example, let’s ignore file 2.
I have File 1, where I update component A. I publish File 1 because it is a library. After some time I got a notification in File 1 saying Component A was updated (and besides that, I can see components published 1 month ago also in this notification).
Yes, File 1 might have several instances of A.
I hope it is just a bug, but it confuses us.
Jan 16, 2024 4:18 AM UTC
Thanks for the feedback. I will share your insight internally!
Luisa_Soto
Aug 13, 2024 3:56 PM UTC
Hey. Do you have an update on this? i’m getting the same issue. I imagine is because of this:
Library A has a button component. i published it.
I crated Library B that uses Library A as a base to make an organism using the button from above.
For some reason i had to bring a component from Library B to Library A, so technically i was in a loop of libraries, and i removed all components from B into A, leaving library A clean.
After all this, having removed the components and the library from B into A, i’m still getting updates of Library A inside that same library A.
Is there a fix?
Aug 19, 2024 3:57 AM UTC
Hi there,
Thanks for reaching out. It could be an issue, so could you submit a bug report detailing the steps that led to this issue? You can do so by following the link:
Figma Learn - Help Center
Our support team will look into it.
Thanks for your understanding.
Toku
