Nov 26, 2024 11:03 AM UTC
findWidgetNodesByWidgetId() Not working?
Hello. I’m trying to store and log the amount widgets on the page using findWidgetNodesByWidgetId (API docs) but the output is coming up empty. I want to see in the console how many are on the page and store the widget ID’s and position.
I can correctly log the individual widget API upon click but seemingly not store them or log. Can anybody see what’s going on?
const { widget } = figma;
const { Text, useSyncedState, AutoLayout, useWidgetId, useEffect, usePropertyMenu } = widget;
function DotWidget() {
  const [count, setCount] = useSyncedState("count", 0); // Placeholder array and function to handle counts
  const widgetId = useWidgetId(); // I get a deprecated warning on 'useWidgetID' for some reason.
  // Logs the Widget ID upon mount
  useEffect(() => {
    console.log(`Current Widget ID: ${widgetId}`);
  // 🚨 I have 2 functions to find and count the widgets on the current page:
  // Function 1️⃣ - Uses 'findWidgetNodesByWidgetId()' which recommended by the Widget API but it doesn't find any widgets
  const findWidgetsAsync = async () => {
    await figma.currentPage.loadAsync();
    const widgetNodes = figma.currentPage.findWidgetNodesByWidgetId(widgetId);
    console.log(`Found ${widgetNodes.length} widgets with ID ${widgetId}:`,
                widgetNodes.map(node => node.id));
    return widgetNodes;
  // Function 2️⃣ - Leverages a Plugin API method currentPage.findAll(). This function works but is extremely slow
  // const findWidgetsAsync = async () => {
  //   await figma.currentPage.loadAsync();
  //   const widgetNodes = figma.currentPage.findAll(node => node.type === 'WIDGET' && node.widgetId === figma.widgetId);
  //   console.log(`Found ${widgetNodes.length} widgets with ID ${figma.widgetId}:`,
  //               widgetNodes.map(node => node.id));
  //   return widgetNodes;
  // Exposes menu on click
  usePropertyMenu(
        itemType: 'action',
        propertyName: 'findWidgets',
        tooltip: 'Find Widgets'
    // Shows an action with text 'Find Widgets' to run the function
    async ({ propertyName }) => {
      if (propertyName === 'findWidgets') {
        figma.notify('Finding widgets...');
        const allWidgets = await findWidgetsAsync();
        console.log(`All Widget IDs on this page: ${allWidgets.map(widgetNode => widgetNode.id).join(', ')}`);
        figma.notify(`Total DotWidgets: ${allWidgets.length}`);``
  return (
    <AutoLayout
      padding={8}
      fill={'#FFF'}
      cornerRadius={50}
      horizontalAlignItems="center"
      verticalAlignItems="center"
      <Text fontSize={16} horizontalAlignText="center">
        {count}
      </Text>
    </AutoLayout>
widget.register(DotWidget);```
![image|690x430](upload://8HLcU9kz06rTNRXgvqkiuUlFSnd.png)
tank666
Nov 26, 2024 5:17 PM UTC
The useWidgetId() (or useWidgetNodeId()) hook returns the node id. So your widgetId constant stores WidgetNode.id, but it should be the value provided by the figma.widgetId (or WidgetNode.widgetId) property (the same value as in manifest.id).
Nov 26, 2024 7:00 PM UTC
Amazing, thanks @tank666 - this solved my issue. Been staring at this for day.
Cheers!
