Martyn_Bowis
Mar 4, 2024 4:55 AM UTC
Figma Plugin export {}; added during compile causes crash
I have tried to follow this guide:
figma.com
Now, the code.js file always gets the following added as the last line:
export {};
This then causes the plugin to crash.
I can fix the issue by commenting out or deleting that last line.
The plugin will then run again without issue.
However, the next time I make a change to the code.ts file, the hot reload runs and that line is again added to the bottom of the code.js file, causing the plugin to crash.
What is causing that line to be added?
How to resolve this error please?
Note that:
manifest.json
eslint.config.js
tsconfig.json
package.json
Power Member
Mar 4, 2024 5:24 AM UTC
Remove moduleResolution and module.
Martyn_Bowis
Mar 4, 2024 9:55 PM UTC
Thanks @Gleb !
Yes, that fixed the issue.
