Kat
May 3, 2021 5:29 PM UTC
Excluding a frame level from asset hierarchy?
Ultimate Goal
Arrange my team library file better by using auto-layout to group and add descriptions to components and their variants.
Problem
The auto-layout grouping/layer level is showing up in the asset panel breadcrumb, which adds one unnecessary level to click through to get to the assets.
Is there a way to format the frame or auto-layout layer to tell Figma to ignore that level when arranging the assets panel?
Sillanmaki_Aleksi
Aug 2, 2022 7:02 AM UTC
Have you found a solution or work around yet?
Nicole_Saidy
Mar 15, 2023 2:04 PM UTC
+1 have you found a solution?
Nicki_Arbol
Jun 30, 2023 3:08 PM UTC
+2, i need this so bad
Patrick_Johnson2
Jan 5, 2024 5:43 PM UTC
Adding to the need for this.
I expected to add an underscore or asterisk to the beginning of a frame name to exclude it. But no.
Michelle_Conard
Jan 13, 2024 1:28 AM UTC
Also looking for a solution to this. An example: I’m setting up some stock photography as components. I want them all contained in a frame so I can keep things organized, but then that frame adds an extra unnecessary click as I try to access those components from a different file.
Figma
Andrew_Reifman
Jul 11, 2024 6:46 PM UTC
Still needing a solution for this as well.
Joe_Lakey
Sep 20, 2024 8:01 PM UTC
I’ve wanted to be able to do this since I started creating Figma libraries almost three years ago. I would suggest making this a feature request except that Figma’s roadmap seems completely arbitrary and doesn’t give consideration to even highly-requested features (then closes the thread automatically). Maybe if it gains some traction here someone will notice.
Juuso_Kantonen
Oct 31, 2024 1:20 PM UTC
I found a workaround! Grouping components with section without a name will not mess up asset hierarchy.
