Download option while using figma code generation
  • February 2, 2024
  • 10 replies
  • 598 views
When using Figma plugin for code generation in dev mode, the output is usually displayed in one of the subsections Inspect panel.
This output of code generation is available with one option - “Copy”
Is there a way to download the codegen output ?
Best answer by nirvana7
Thanks for the response. However this is not an exiting code generation plugin that i am trying to download.
I am creating a new plugin and want an option to download the generated output.
Can you please guide me for the same.
tank666
February 2, 2024
Some codegen plugins provide the ability to export code snippets. Just click on the “Inspect settings” icon next to the plugin name and select the item you need.
nirvana7Author
February 2, 2024
I am unsure where this setting is.
This is what i see in my inspect panel for a codegen plugin
tank666
February 2, 2024
“Inspect settings” icon.
nirvana7AuthorAnswer
February 5, 2024
tank666
February 5, 2024
In this case, you need to study the following docs:
figma.com
https://www.figma.com/plugin-docs/api/CodegenPreferencesEvent/
In short: add codegenPreferences to the manifest, listen to the preferenceschange event, pass the code to the UI and call the download function.
nirvana7Author
February 6, 2024
Thank you, i have already checked some of the docs and will explore others too.
Also you mentioned call the download function, are you referring to some native method for this ? Any example that i can leverage ?
tank666
February 6, 2024
stackoverflow.com
You can also Google it yourself.
nirvana7Author
February 6, 2024
Ah nice, a javascript function is even better. Initially i thought if there is any native support from Figma for downloads. Thanks @tank666
Burbach_Brandon
March 7, 2024
Hi @nirvana7 and @tank666, I am working on a similar problem where I am trying to access the native HTML code generated by in the Figma Inspect panel shown below via the API →
Is there a way for my plugin to access this natively generated code via the API?
tank666
March 7, 2024
In this screenshot I can see that the HTML code was generated by a third party plugin. In this case, I suggest you contact its creator.
