Mar 15, 2023 10:45 AM UTC
Does starter plan delete projects after 30 days?
Does the starter plan delete your projects after 30 days?
I’m a bit confused about the limitations
TIA
Celine_Solution
Mar 15, 2023 4:12 PM UTC
Hi @Aimee_Jade_Nel,
The starter plan doesn’t delete your projects after 30 days.
  • When you delete a file, Figma will remove the file from the project for all collaborators. Then, you will be able to access the file from your deleted files folder.
  • View, restore, and permanently delete files in the Deleted tab of your Drafts. Figma stores deleted files indefinitely, until you or another collaborator deletes them forever.
    Hope it clears out, you can also find more information in our article “Delete and Restore files”, here: https://help.figma.com/hc/en-us/articles/360047512294-Delete-and-restore-files
Also, I think you mixed up with the version history? Members of Starter teams can only view 30 days of a file’s version history. More information on View a file’s version history here: https://help.figma.com/hc/en-us/articles/360038006754 Hope it helps!
Celine_Solution
Hi @Aimee_Jade_Nel,
Feb 8, 2024 1:40 PM UTC
Does view mean if I drop from professional to starter I will loose all version histories (so they are deleted) or can I access them again after upgrading to professional again (no matter when I do that)?
Feb 8, 2024 2:56 PM UTC
Hey @efiohw ,
If you Upgrade to a Professional team again, you’ll be able to access all versions right back to the creation of your file, even if that’s before you upgraded.
(The 30-day version history limit applies to version you can access, and not versions we store on our system. ) Hope this helps!
Farah_Kamila
Sep 27, 2024 6:44 AM UTC
Hello, I just received that my education plan will expire in 3 days. Does that mean my starter teams (free) will also be deleted?
Sep 27, 2024 10:30 PM UTC
Hey @Farah_Kamila,
No - your files won’t be deleted, but keep in mind that you can only have 3 collaborative files within a Starter team. You’ll want to move any additional files into your Drafts.
