Mohammed_Vasim_Ansari
Apr 23, 2022 6:53 PM UTC
Does figma support design operation with devices like Wacom or Huion?
Hello! Guys, wondering if anyone has faced the issues while operating in Figma with the design tablets like Wacom and Huion. Basically, I use the Huion tablet with the stylus to do my design work but with Figma, it is overshooting in drag while using the pan tool ‘It just run-off the screen’. Just want to know if it is the issue with Figma not supporting these sorts of devices?
Power Member
Apr 24, 2022 1:31 AM UTC
My Wacom Intuos 3 tablet works perfectly fine in Figma (macOS)
Pierre_Bremell
May 12, 2022 9:09 AM UTC
@Mohammed_Vasim_Ansari Did you solved this problem?
I’m using Wacom Intuos 3 and have the same problem. Every time I’m using Right Click my file freeze and I have to reload. New computer, new installation for Figma and Wacom. Nothing helps.
Regards,
Pierre
May 12, 2022 9:40 AM UTC
@Pierre_Bremell Oh sorry to hear that dear.
For me it is still the same ‘run-off the screen’ while panning around 😦
Dmitri_T
Nov 27, 2022 7:28 PM UTC
Have you found a solution for the issue? I have the same problem with Huion Kamvas 13
Nov 28, 2022 2:37 AM UTC
Not yet, my friend 😦
Romijn_van_Soest
Oct 1, 2024 8:03 AM UTC
Same here still, did you fix it yet?
PandaPunch
Mar 13, 2025 7:20 PM UTC
If you're on a Windows device, I found this solution on Reddit. Try disabling the Windows Ink. https://www.reddit.com/r/huion/s/pJj5sys6w8
varelsen
Mar 19, 2025 11:09 AM UTC
Regards,
Pierre
I have the same issue as well with my Wacom Intuos. Talked to Figma support but without a solution :/
