Thilo_Becker2
Jun 11, 2024 2:38 PM UTC
Custom Shortcut Modifier stopped working
Before it was possible to use a modifier key like CTRL
Example:
I use CTRL + Shift + A for my Shortcuts plugin to set Align between Items on “Fixed”. This was working fine for years.
Suddenly it executes add Autolayout (Shift + A) even though the Shortcut is correctly applied and visible in die macOS menubar. So its ignoring the CTRL modifier key now.
Is this intended?
Jun 13, 2024 6:26 AM UTC
Hi @Thilo_Becker2, Thanks for reaching out about this. I understand that it can be frustrating when things don’t work the way they used to.
Currently, Figma doesn’t have a built-in feature for assigning custom shortcuts. It seems you might be using the Create keyboard shortcuts for apps on Mac function.
I’ve tested this by assigning [CTRL + Shift + A] to a function under the Plugins menu, and it added Auto Layout as you mentioned. It might be intended behavior, but I’ll check internally to see if there’s any information about this to assist.
In the meantime, you might want to try exploring other combinations that could work for you. Moreover, if anyone has insight or workaround for this, please let us know.
Thanks again for reaching out.
Thilo_Becker2
Jun 25, 2024 7:45 AM UTC
It is working again. Wohoo 🥳 Thanks
Thilo_Becker2
Jun 28, 2024 8:20 AM UTC
And its not working again, but now we know why. Suggest auto layout…
