Mollie
Sep 1, 2023 7:09 PM UTC
"Create component set" is gone now? How does one
I’m trying to create a variant for dense mode of a table and I don’t want to have to completely recreate said dense table to add it as a variant of the standard table. I can no longer select 2 things and “create component set.” Does anyone have a workaround for this or know why they removed it?
Marian_Brchan
Sep 1, 2023 10:43 PM UTC
You should be able to create a component set from two or more frames.
They just can’t be components, but regular frames instead.
Mollie
MollieAuthor
Sep 5, 2023 1:20 PM UTC
Thank you! that helps. It’s unfortunate that you can’t copy and paste to add variants vs. having to create a whole new component set and remap instances.
Marian_Brchan
Sep 5, 2023 1:43 PM UTC
One trick you can do is to create a new variant within the component set (or duplicate existing) → paste the new frame to it → remove everything else → ungroup the pasted frame.
If needed you can also copy the frame properties from the nested frame to the component variant before ungrouping.
skylar1
Aug 14, 2024 10:59 PM UTC
This feature is seemingly removed with the big update. Any help on this would be greatly appreciated!
Travis2
Aug 14, 2024 11:59 PM UTC
I might be misunderstanding what you’re trying to do, but you can still make component sets, for some reason they hid it inside the overflow here.
Screenshot 2024-08-14 at 7.58.42 PM
Mohamed_Rashed
Aug 21, 2024 3:18 PM UTC
You must select all frames then choose create multible components, then you will find combine as varients button, click it to see all frames converted to varients
Tobela_Fadi
Oct 17, 2024 7:15 AM UTC
Screenshot 2024-10-17 at 09.11.37
Emos_Biseyler_Yapiyor
Oct 18, 2024 12:16 AM UTC
I have two frames selected but still I can’t find that button. Is it gone for good?
Nellya
Power Member
Oct 18, 2024 7:10 AM UTC
@Emos_Biseyler_Yapiyor Are you sure you selected two separate frames? Can you share full screenshot?
Oct 21, 2024 1:10 AM UTC
I accidently group the two frames together and that was why the component set option wasn’t shown. Now it’s settled 🙂
