Sorosh_Azizi
Jan 23, 2024 10:28 AM UTC
Component set boxes are so huge as default!
HI there !
When i want to add variant to a component or want to create a component set, padding of the box is 200 px 😐
i try to set as default setting in edit menu but it doesn’t work for component set size and every time i add a variant to component set everything changes like pic blow.
any solution?
Jan 24, 2024 1:27 AM UTC
Hi there,
Thank you for your post. I’m unsure why the default padding size was set to 200px. However, have you considered implementing auto layout for the component set? This approach would give you greater control over the set.
I’m also open to other suggestions! If you have any questions or need further clarification, please don’t hesitate to ask.
Toku
Karim_Lounes
Jan 22, 2025 4:00 PM UTC
Hi. I have the same issue. When creating a component, the default vertical gab is 50, the default paddings are 100. These values are hidden since I can only see them once I create an autolayout.
I remember a few months ago, I attended a Figma webinar and they “very quickly” showed a fast short cut to change those using a mouse wheel scroll while holding on some key.
I cannot seem to find the way to reset those values back to 10px or 12px so I don’t have to manually change them every time I create a component. It’s become truly an annoyance at this point.
Thanks
Nellya
Power Member
Jan 22, 2025 4:12 PM UTC
​@Karim_Lounes padding is a doubled nudge amount size
