Regi
Oct 18, 2024 8:11 AM UTC
Changing 'external' library mode
Hello,
I’m working on a plugin for changing collection modes.
Using figma.teamLibrary.getAvailableLibraryVariableCollectionsAsync() I get the available collections, but they are not returned as collection objects, therefore I can not use them with setExplicitVariableModeForCollection directly, as far as I can tell. Since that requires a collection object.
Furthermore the getAvailableLibraryVariableCollectionsAsync() only provides the library keys and not an ID. What is the actual logical way to go about this? Considering my library is not a local library that I want to change a mode for.
Thank you.
Power Member
Oct 18, 2024 9:16 AM UTC
Posted this on plugin devs discord previously, reposting here. It’s very convoluted.
  1. Fetch All Remote Collections: Use getAvailableLibraryVariableCollectionsAsync() to get the list of remote collections.
  2. Import Variables from Remote Collections: Use getVariablesInLibraryCollectionAsync() to fetch variables from each remote collection.
  3. Import a Single Variable by Key: Import a variable using importVariableByKeyAsync() to bring it into the local document context.
  4. Get the Local Variable’s variableCollectionId.
  5. Get the Variable Collection by ID: Use getVariableCollectionByIdAsync() to fetch the collection and its modes.
async function getRemoteCollectionsWithModes() {
    // Step 1: Get all available remote library variable collections
    const libraryCollections = await figma.teamLibrary.getAvailableLibraryVariableCollectionsAsync();
    const remoteCollections = [];
    for (const libraryCollection of libraryCollections) {
        try {
            // Step 2: Get variables from each library collection
            const variables = await figma.teamLibrary.getVariablesInLibraryCollectionAsync(libraryCollection.key);
            if (variables.length > 0) {
                // Step 3: Import a single variable from the collection
                const importedVariable = await figma.variables.importVariableByKeyAsync(variables[0].key);
                const collectionId = importedVariable.variableCollectionId;
                // Step 4: Get the variable collection by its ID to access the modes
                const variableCollection = await figma.variables.getVariableCollectionByIdAsync(collectionId);
                // Add the collection and its modes to the result array
                remoteCollections.push(variableCollection);
        } catch (err) {
            console.error(`Failed to process collection: ${libraryCollection.name}`, err);
    return remoteCollections;
// Example usage
getRemoteCollectionsWithModes().then(remoteCollections => {
    console.log(remoteCollections);
This is for getting the modes and collections, then you can use them to set modes just like with local collections.
Here is the plugin I built with this, it’s called Quick Mode and it allows you to switch modes on selected objects using the quick actions menu without having to dig through the props panel: https://www.figma.com/community/plugin/1405229225049855076/quick-mode
tank666
Oct 18, 2024 1:37 PM UTC
I previously described the logic in this thread:
Power Member
Oct 18, 2024 2:25 PM UTC
I wish I saw this before 😆 Would’ve saved me a couple hours tinkering with this to get the code above.
