Alok
Sep 10, 2024 9:46 AM UTC
Remove all components using the shortcut Ctrl + Alt+ B. Then, on the right side of the screen, you’ll find the text section where you can adjust the font as needed
Kaley_Sutton
Sep 10, 2024 5:06 PM UTC
Hi, tried the shortcut but couldn’t get it to do anything. Is there some workaround?
Raphael_M
Power Member
Sep 11, 2024 4:22 AM UTC
Some of your text is using “styles”. Detach them first.
Make sure you’re also selecting a text layer (T symbol) for the Typography property to show up.
Kaley_Sutton
Sep 11, 2024 7:21 PM UTC
THANK YOU SO MUCH! This solved my problem.
