shijia.me
Jul 26, 2022 9:52 AM UTC
Can I use figma plugin API to do the same thing as "resize to fit" button in panel
Sonburn
Feb 10, 2024 12:29 AM UTC
Did you ever find a solution?
tank666
Feb 10, 2024 10:14 AM UTC
The easiest way is to turn off the clipsContent, get the absoluteRenderBounds, and then use the resizeWithoutConstraints method and change the coordinates of the children if required.
Johannes_Vollmer1
Oct 30, 2024 12:00 PM UTC
For anyone coming here, I’ve coded up a solution that worked pretty well for my use case. Some edge cases might not be working yet though. Resizes a parent element around all children, assuming absolute positioning of both.
Github Gist - johannesvollmer / Resize to Fit (Figma Plugin API)
