Vincent_Huss
Dec 7, 2024 7:54 PM UTC
API : the SVG export is undeterministic when given 2 exact copies as inputs
Hi,
when i export nodes with node.exportAsync({format: 'SVG'})
I am then relying on a hash comparison of the content to know which ones are identical or differents.
This works well for ‘png’ and ‘jpg’, but with SVG, the content is different even though the 2 nodes are an identical copy.
When opening the 2 resulting svg files and looking at a diff, i see that there are some tiny differences related to float rounding (im attaching a screenshot of the diff)
Is this solvable ? is this a fatality ?
without the ability to recognize similar svg export, i won’t be able to propertly factorize my images exports.
And if nothing can be done about this, are the png / jpg indeed more deterministic as the few tests i did seem to indicate ?
Thanks if you have any inputs.
Best
