    On prototype mode I want to select nodes which are highlighted automatically.
** Switch to prototype mode**
  • I have two artboards with the same content
  • On the first artboard I select a certain node to create a prototype interaction
  • On the second artboard the same node is being highlighted automatically.
    See screenshot
Is it possible to select the highlighted node on the second artboard without multiple clicking or cmd+click + shift+return?
This would significantly speed up the creation of interaction on the same element on other artboards.
Also curious about this - I have often wondered what the purpose of ‘highlighting’ the similar layers is. I absolutely expected this to be the primary use case for it the first few times I noticed the highlighting, and was disappointed that it’s not possible. Would save a lot of time.
Figma Learn - Help Center
Ah, I see, thanks!
