The master component instance of the library file linked to the draft file being worked on suddenly appears only in the layer of a white box.
There is no problem with the master component itself.
In other files it looks fine, but only in certain (most important) files it looks like a white box.
instance of draft file
master component of library
Anyone know the cause or solution?
What I’ve tried:
- Stop publishing the library file and re-publish again → It doesn’t work
- Change the auto-layout of the component arbitrarily → Some layers are visible in the instance but, some layers are disappeared.
- Re-launch the Figma app after closing. → It doesn’t work
