I’m stuck and hope someone here can help… I have a shared team library of components. I’d like to use that library to build larger sections in a template that I would then duplicate for each new website design, so that I can start with the same elements. However, rather than having styles defined on the library itself, I want to apply styles at the template level.
So far, the only way I can tell that can be done is if I override each style already set in the library components. Is that the case, or can I have library styles automatically overridden somehow at the template level?
