Usually, when combining components as variants and if properly named, the Variants group will be automatically assume their common name.
But sometimes it just names is “Component x”. I verified if all components are correctly named and they are. What’s wrong?
Screenshot 2021-04-12 at 12.28.23
Screenshot 2021-04-12 at 12.28.32
This probably happens because the names already somewhat adhere to the variants name notation instead of the regular / nesting (you are setting the property and value there with =). So it thinks these already are variant names and keeps the property and values as is. If you remove the = sign it should work as you are expecting.
I removed “Theme=” and it works! I just have to rename the property to “theme”, but it’s way easier. Thank you!
