Hi there,
as indicated by the green arrows in the image, how to round the corners of an irregular shape like this?
outcome
This is the outcome I want to achieve.
If those corners consist of only single points, you can select them and increase the vector corner radius.
I tried, but it didn’t work for the two points that I circled out.
It only works on points with two connections. If you delete the line that connects the two points through the shape, it will work.
Thank you, that makes sense. The shape is a vector and I can’t find ways to delete the line between the two points, so I use Pen to outline a new shape and round corner all points, it works. Thanks!
