In the documentation, it mentions
“Setting relaunch data on instance nodes or nodes inside instances is currently not supported.”
However, what I’m wondering is, does this mean if I setRelaunchData on a Component, will that same data follow each instance of that component?
Thanks ahead of time!
Hi @Jimmy_Morris, i just tried setting relaunchData for component, instance and node inside the instance. If you set relaunchData for a component, then data follows all instances of that component. Setting relaunchData for an instance or node inside instance worked, although it is written that it is not supported.
Amazing! Thank you, I probably should have just tested it myself 🤦‍♂️
