I really love “nested instance properties” feature but it works for one component instance only. It would be useful if nested instance properties were available when I select several “parent” instances.
My example
🛠️ Component structure:
- component Label - used for different statuses - has text property Label for text inside 2) component Table Cell - used for building tables - has variants for different types of cells
Case: I create column of statuses in the table, it includes cells which include label. If I want to update text in one label I can use nested label’s text property. But when I want to update text in several cells nested instance property disappears and I need to select label instead of cells or use some plugin for bulk text update.
PS: thanks to figma team for your incredible work ❤️
