Hi there !
Since this morning, when I add an image on figma (whether importing it from my desktop or pasting directly does not change anything), Figma tells me that there are unsaved changes and if I leave the window and I restart the draft, I only have empty blocks without images, I tested on another computer and I have the same problem…
do you guys know how to fix that ?
thanks !
thank you for your help, I don’t know how, but everything seems to be working out
the problem is not really solved
I have the same issue right now. I couldn’t see the images in FigJam and also Figma. Here is the screenshot:
Hey Josh, I have sent an invitation to support-share@figma.com. I have the same issue in FigJam also, couldn’t see the images. Thanks for your support in advance
Hi, I just started having this issue for the first time today.
Interestingly enough, the issue was only seen within my latest file though, and duplicating said file actually fixed the issue in the new copy. I also don’t have that issue if I create a new file from scratch. 🤷
Hi, yes it also works for me, I copied the file and now I can see the images. Weird 🤔
