I don’t know what is happened but i open my figma program normally and i cant see all the grouop created, used and commented. I can select the group, i can see listed every single part in the left bar, i can see the comment. And the visibility is switch on… Anyone knows ho to fix this problem?
Pay attention to the layers panel, a mask has been applied to your group. Remove the mask, and everything will be as before.
how can Ido it?
Figma Help Center
i don’t the mask. may you indicated? because i’m able to generate a newone but i don’t see the mask that you indicated
In your second screenshot, the “Group 138” layer is selected and has a mask applied to it. Scroll down the layers panel below to find the layer mask. Select this layer and click on the mask icon in the toolbar.
done!!! thanks
