hi, sorry if it’s too late, but here…
- general way of creation and use of patterns in vector-based software is to make the pattern first, and make it into a component
- (since figma has no “tile-filling”) create a few clones of it until it covers the area you want to
- scale accordingly
- apply mask or object-intersection
- make sure the final export has/dont have pixels with alpha-transparency (depending on your intention)
and also, start with everything 10x your intended export size – it will be easier to deal with if your thing is 1000px instead of 100
here is a generalized example, similar to what you showed: https://www.figma.com/file/ngTOMOUwxLbdgYHw7fsPk9/cross-lines
the point for this entire system is so you can just change anything separately, and it will affect all subsequent steps (unless you deliberately detach cloned components):
