I want to make a fully flexible design with smart resizing for every iPhone screen one pretty smart set for every element. Now when I want to resize the design from iPhone X to iPhone 8 and set element constraints scale I am getting not what I expected. The problem that every iPhone screen has different proportions. I want the circle to remain a circle but it turns out to be an ellipse. Do you have solutions for this?
The only way to keep the aspect ratio of resized elements is to use a tricky workaround.
Figma
You can utilize a normal frame and have it fix size and pin to the edge. Normal frames can be inside auto layouts, and you can get some pretty cool results!
Ah, I realize that I might’ve misunderstood the original question. Another workaround I’ve done is create different sized components for the item itself. When I go to a different sized frame, I can adjust it to the appropriate size. Still a bit of a work around, but it does give some flexibility.
Just make sure your layers are named the same thing and any overrides you do will transfer between the component variants.
This topic was automatically closed after 12 hours. New replies are no longer allowed.
