Hi, I used this code to generate table with multiple columns and rows, where rows contain lines. Lines are grey and not hidden, but for some reason they are invisible in Figma.
What I am doing wrong that they are not showing properly?
Line generating code:
// Generate lines
const rowLine = figma.createLine()
rowLine.name = 'Line ' + (j+1)
rowLine.resize((908/countColumns),0)
// Change color of lines
const colorR = 224 / 255,
colorG = 224 / 255,
colorB = 224 / 255
rowLine.strokes = [{type: "SOLID", color: {r: colorR, g: colorG, b: colorB}}]
row.appendChild(rowLine)
Whole code:
figma.showUI(__html__, {height: 250, title: "Table Generator"})
// Calls to "parent.postMessage" from within the HTML page will trigger this
// callback. The callback will be passed the "pluginMessage" property of the
// posted message.
figma.ui.onmessage = msg => {
// One way of distinguishing between different types of messages sent from
// your HTML page is to use an object with a "type" property like this.
if (msg.type === 'actionGenerate') {
const {countRows, countColumns} = msg.formDataObj
// Generate main (parent) frame with custom name and properties for proper auto-layouting
const parentFrame = figma.createFrame()
parentFrame.name = 'Table ' + countRows + 'x' + countColumns
parentFrame.layoutMode = "HORIZONTAL"
parentFrame.paddingTop = 25
parentFrame.paddingRight = 16
parentFrame.paddingBottom = 25
parentFrame.paddingLeft = 16
parentFrame.primaryAxisSizingMode = "AUTO"
parentFrame.counterAxisSizingMode = "AUTO"
// Generate lines according to 'countRow', name and resize them
for (let i = 0; i < countColumns; i++) {
const column = figma.createFrame()
column.name = 'Column ' + (i+1)
column.layoutMode = "VERTICAL"
column.primaryAxisSizingMode = "AUTO"
column.counterAxisSizingMode = "AUTO"
parentFrame.appendChild(column)
for (let j = 0; j < countRows; j++) {
const row = figma.createFrame()
row.name = 'Row ' + (j+1)
row.layoutMode = "VERTICAL"
row.primaryAxisSizingMode = "AUTO"
row.counterAxisSizingMode = "AUTO"
column.appendChild(row)
// Generate lines
colorG = 224 / 255,
colorB = 224 / 255
// Select generated table and zoomm-in
const selectFrame : FrameNode[] = []
selectFrame.push(parentFrame)
figma.currentPage.selection = selectFrame
figma.viewport.scrollAndZoomIntoView(selectFrame)
figma.closePlugin('Table generated successfully :)')
} else if (msg.type === 'actionExit') {
figma.closePlugin();
