I’d like to get current user’s country, so I can show my plugin with the appropriate system language, and I tried several approaches:
  1. HTML Geolocation API
    Figma plugin’s origin is set to *, so I can’t use navigator.geolocation.getCurrentPosition() inside Figma plugin.
  2. Geolocation by IP address
    This works, but the downside is that, this is an asynchronous method, which can cause a fraction of a change when the React rendering the page with given language context.
So is there any solution for this ?
Thanks.
Using a country to determine user’s language is a bad idea in the first place (and I don’t think there is an api for that). Imagine you are traveling to another country or simply using a VPN — you won’t be able to read anything. A much better way is to use the user’s locale. I think it should be available.
@Gleb figma doesn’t support the navigator object so there is no way to directly access the users preferred language 😞
Correction: you can access the users language!
You will need something like this in your ui.html:
parent.postMessage({ pluginMessage: { navigator.language} }, '*')
and then this in your code.ts
figma.ui.onmessage = msg => {
msg; // do whatever you need with the language here
