I’d like to be able to have a prototype start at a specific y-height. My work around right now has been to use a timed interaction at 1ms to scroll to the desired starting y-height, but the change is visible. This behavior is needed in order for the sticky header to work properly since the scroll behavior in the experience I’m working on is reversed.
Turns out I wasn’t using this feature incorrectly.
Might’ve been apparent to others, but what I found out is that you can have the contents of a frame be inverted and the sticky attribute will be related to the containing frame. If it is out of the frame, it will be at the top of the container frame.
