I’m trying to detach an instance of a component, and it’s not working now. It was working till yesterday. I’ve tried using the KB shortcut, the right-click menu, and the instance menu in the inspector. Any tips?
If this instance is nested in another instance, you can’t detach it as you can’t change objects inside instances. You can only detach top-level instances.
Thanks Gleb! That helped
I think this can be done if you option drag to make a copy of the master component and then it will let you detach said copy.
Thanks the copying trick did the job! Well Appreciated!
Having issues detaching a main component even right after I create it.
Make a copy
That worked! Thanks.
This still works today and is a huge life saver! Thanks!
Just Copy & Paste That Instance - Then Detatch Copied 1
I just did the copy and paste now and it worked. This just saved me. thanks you so much.
I try to detach a group of components. I made a copy but still, I’m not getting an option to detect it, not in the property panel and not on the right klik or option command B. Please help.
This is the actual and easy-peasy solution ☺️ 😃
