I have a component in the library.
If I update properties on the instance inside the library (top red selection) – the nested property values (bottom red selection) are updated.
However, it doesn’t update values if I publish the library and try the same in a separate file (where the library is connected).
Lightshot
  • Icon 32 property and all following properties are configured the same way and work perfectly though 🤔
A small addition.
If you select component and swap instance manually – all works fine as well Screenshot by Lightshot
