Hello,
After the last update on October 24, 2024, all files have disappeared. The direct link shows a message stating that the files have been deleted. Could you please advise if it is possible to recover the files?
Hi there, welcome to the community!
If it says that your file has been deleted, as a first workaround, please check your Trash folder to see if you can restore them: [Delete and restore files]
The good news is that we don’t permanently delete files from Figma unless you manually click “delete forever” or if you delete the team or project that the file was in.
You will be able to restore the file by clicking on Trash and locating the file you want to restore. Right-click on the file and select Restore.
To see all available files that can be restored, please make sure that you also set the “Created by” filter to “anyone” rather than “you.” You, and anyone else who had access to edit that file should be able to find it and restore it this way.
If this still doesn’t help, can you share a quick screenshot of the error message, and share a link of this file here? This will help us to locate the file and see what may have happened. (If you prefer not to share it publicly, you can reach out directly to the support team by filling out this form: here) Thank you
The cart is empty as well. In the conversations, I found direct links, but the files do not open; instead, a notification appears stating that the file has been deleted or hidden.
Thanks for the details. This looks odd, not sure what’s happening here 🤔 As mentioned, if the workarounds don’t help, can you share the exact error message (a screenshot if you are able to), and share a link of this file here? (you can also find in your browser’s history for example). We will need this in order to try to locate the file.
Or, you can reach out directly to the support team: here if you prefer. Thanks!
Links to the two files that were available on Thursday.
https://www.figma.com/file/cp8WhnRQqjJbpIyXtK4Fk2/Newtube?type=design&node-id=228-30944&t=fcGlf27xPfmyh6MQ-4
https://www.figma.com/file/QSiHWkPceIouvcEVmExsmo
Thanks for the links of the files! It looks like that your files have been deleted via your Draft folders.
We’ve recently made some changes to how drafts work, and wonder if that may be playing a role here: https://help.figma.com/hc/en-us/articles/18409526530967-Updates-to-how-drafts-work
For security reasons, I have created a support ticket on your behalf for further investigation and assistance from the support team directly to recover them. For your reference, your ticket number is: 1162532. Please continue the conversation via email with our support team, you should have received my message. Thank you!
Thank you. In total, about 20 files have been lost.
Hey @Nataly_Antonova , I see on the backend that you were able to recover your files by restoring your deleted team.
For others who may encounter a similar issue, please check if your team has been deleted. If so, you should be able to restore it using the link provided in the email you received following the deletion of the team.
You will only see this email if you manually delete a team, but if this has been done by accident, you can restore it by clicking ‘Restore your team here’ in that email. Deleting a team doesn’t affect any files belonging to other teams or files in your drafts.
Here are a couple articles from our Help Center with more information:
I’ve gone ahead to mark as closed the topic here 🙂
