Auto Layout Grid - Column hug to content
  • May 7, 2025
  • 45 replies
  • 4486 views
Smith_Samuel_D
Hello! 🤠
I was very excited to see the addition of Auto Layout Grid today! Having flexibility for both Rows and Columns at the same time is a game changer.
That said, I immediately ran into not being able to set a column width to “Hug” within a table, which is a bummer. In the attached video, I want the “Audited By” column to Hug to the longest table cell content. I show both the current solution today, and what I am trying to do with Auto Layout Grid.
I can manually adjust the width of the column, I guess, but as you can see, it makes it hard to ensure correct padding without a lot of careful tuning of the width.
Anyone have any solutions? Will this be coming as a fast-follow feature? Thank you!
Best answer by Smith_Samuel_D
UPDATE FOR EVERYONE: Figma has added this and MORE! 🎉
The update a few days ago added Hug AND “fr” (fractional) units to grids! This makes grid AWESOME! Thank you Figma for adding these features in!
https://www.figma.com/release-notes/?title=hug-and-fractional-units-for-grid
Chris_Kerr1
  • May 7, 2025
Yeah 100%, this is a major shortfall. I also got excited for this new feature.
In particular, being able to have asymmetrical layouts. For example a desktop form where the left column (1fr) contains the section header and instructions and the right column (2fr) contains the form. I can set this up, however I run into the Hug issue.
The form has conditional exposure of form inputs based on user selection, and as a result the parent container height will change. Forms often contain multiple sections this then prevents the form height from adjusting as it would in a column-based auto-layout parent container.
If anyone has a workaround for this, i’d be really interested. I should also say the idea is that I could create a UI kit component to handle this use case so that design teams don’t have to worry about it, it just works OOTB without having to craft their own layout at the project level.
Laurentiu
  • May 8, 2025
Here for a workaround
Marc_Robinson
Yup! had to look this up because I wanted the autolayout to hug the height of cards that it contained, and I can’t.
Mykyta1
  • May 8, 2025
Same camp, was very excited about this only to find out it doesn’t work like the usual auto layout would. I have a hard time believing it was an oversight, they must have discussed it internally to make the decision for the grids to be unresponsive.
From my perspective, it could be as simple as just having a ruleset for grids to be either corresponsive with a min./max. cell height & width or fixed (as it’s working already).
Would be cool to hear from the Figma team on this.
Joey Lane
  • May 8, 2025
Yep. Same issue for me. Was hoping to use grid for table layouts, but since grid height cannot be set to hug it is not a viable solution :(
Joshua_Martinez1
While Figma grids are awesome, would be great if we were able to set the grid to hug the content. This way when we add an extra row it will respect the size that is set. Maybe have a button that is duplicate or new row?
Another thing that would be great is if we could use variables inside of grids
nickgould
  • May 8, 2025
Same! Without this, grid is actually unusable for my designs 😭
Jim_Knox
  • Active Member
  • May 9, 2025
Same, pretty unusable without hug
Jelle4
  • May 9, 2025
Same here, needs some hugs.
Laurentiu
  • May 13, 2025
HUG! HUGS! HUGS!
David_Dooley
Feels like a huge oversight to not include it. Grids are pretty much useless until this is added. Back to making additional, unnecessary rows 😔
Ben Rubenstein
Can I set a row height to HUG using the new Grid feature?
I need the row to hug its content.
Teemu_Kumpulainen1
Implement this as soon as possible, please! I was already excited since this would tackle a very specific need in our DS – ie. dividing an autolayout non-50/50 – but the lack of vertical hug totally torpedoes it. 😑
Figma_Support
Not yet. but we’re working on it!
Uri_Berry
  • May 21, 2025
Hug!
Autumn Fields
Manually adjusting the height now, and cannot wait for hug! Would make mockups so much faster
Andrew Stuber
Agreed. The ability to hug cells and the layout itself would be a huge help. Otherwise, this is great!
Andrew Stuber
Adding variables to the gaps would also be great
Johannes Booy
Why release a compromised version? It’s basically useless. The flexibility of the grid is nullified by having to define a height. What’s the point in having the gap-y value in the Figma UI? The default browser behavior for grid is to hug the contents.
Matthew_Ryan
  • Active Member
  • May 30, 2025
Adding my +1 to this!
Very bizarre to launch this without it doing what CSS grid does by default. Very limited use cases for fixed height grids.
Larry_Reynolds3
Here for the HUGS +100
Ari_Kogan1
  • June 3, 2025
just here to pile on more deserved vitriol towards whoever decided hug wasn’t important.
Kolodziej_Ashley
Hi - just reiterating my interest in grids whose height is set to hug content, as well as being able to set variables for gap and padding.
It would be absolutely amazing if I could also set the number of columns by variable as well, so that when I change the responsive mode, I can change the number of columns as well. That would let me have 2 columns starting at tablet, 3 columns starting at desktop, etc.
Paul_Panfalone
This feature is completely unusable until they fix this foundational, basic function. How did this go out the door half-baked??
daken
  • Active Member
  • July 4, 2025
any workaround?
